Activity Forums Boris FX boris graffiti insiffiscient shader support
  • boris graffiti insiffiscient shader support
    Posted by Jean Mathis on August 6, 2009 at 4:35 am
    Hi I use a macbook 2.1 GHZ intel core duo with osx 10.5.6 ans after effects CS4 I just dl the latest boris graffiti demo tried to apply on a layer and get that error message critical error card is reporting insuffiscient shader support. I send messages at th eboris official support for two days already but they don’t really come up with brilliant solutions. Any help highly appreciated.
    Jean
    Jean Mathis replied 17 years, 1 month ago 2 Members · 4 Replies
  • Peter Mcauley
    August 6, 2009 at 11:15 am
    Hi Jean,
    I’m surprised that you are getting this error message when you attempt to use Graffiti 5 on that system within AE CS4 and also that our techs were not able to figure it out for you (they are highly qualified technicians and at the top of their game.)
    Anyway, I’ll work with you this morning to see what we can do to resolve the issue.
    To start, try running the standalone Graffiti keyframer outside of AE. Tell me if this works. If it does then we’ll disable the OGL preview in AE and see if that prevents the plug-in from generating the error message that you are seeing. If not, then we’ll launch the Graffiti standalone and disable OGL previewing in Graffiti and try the plug-in within AE again.
    Please let me know if any of this helps.
    Cheers,
    Peter.
  • Jean Mathis
    August 7, 2009 at 3:05 am
    I got this answer from boris this morning :
    Le 6 août 09 à 15:26, Boris FX Technical Support Team a écrit :
    Jean,
    The graphics card you are running(Intel GMA X3100) Is not supported for the
    level of shader technology needed for some of the effects in BCC (3D objects
    and BCS). There is information on graphics card support here:
    https://www.borisfx.com/download_files/BCCAE6ReleaseNotes.zip
    Matt
    Boris Support
    Pretty much settles the case.
  • Jean Mathis
    August 7, 2009 at 10:10 am
    Actually after downloading a 4,8 mb zip and fumbling around to find some infos. You finally get the answer : They say check out this link
    https://www.borisfx.com/products/OpenGL.php to see if U r card is compatible. Actually its nos so mac friendly altogether. If U have latest
    open gl drivers doesnt matter its just that macbooks for instance are not compatible. I am disapointed I must say.
    Jean
  • Jean Mathis
    August 7, 2009 at 10:15 am
    Actually in after effects CS4 I even cannot activate the open gl in preferences, its greyed, but I checked I have all the latest open GL drivers anybody has an idea why this could be so ? I use Max osx 10.5.5
    an a intel GMA X3100 card on my macbook.
    Best
    Jean
