Activity Forums Boris FX Boris Graffiti 5 and Pinnacle Studio 12 Ultimate
  • Boris Graffiti 5 and Pinnacle Studio 12 Ultimate
    Posted by Stefan Sarkuso on June 26, 2008 at 8:07 pm
    Hi everybody!
    I´m new to this video-editing-stuff and have a question about the plugin boris graffiti 5.2 in my new pinnacle studio 12 ultimate edition.
    I made a video with effects from boris 5.2 – now i want to ad this saved settings to a new clip (different duration). hm, looks like that boris stretches my timeline on the new clip, in totally wrong directions.
    for example: the first effect should end at the 4th second. in the old clip it does, in the new one it ends at second 21 ??
    I´d be glad if someone could help me 🙂
    bye,
    0range
    Peter Mcauley replied 18 years, 2 months ago 2 Members · 6 Replies
  • Peter Mcauley
    June 26, 2008 at 8:18 pm
    Hi Stefan,
    The duration of the effect is dictated by the length of the clip to which it is applied. If you apply the saved 4 second Graffiti effect to a 2 second clip then the effect length can only be 2 seconds. Does this explain what you are seeing?
    Peter.
  • Stefan Sarkuso
    June 26, 2008 at 8:43 pm
    Hi Peter,
    I tried to adjust the duration in the graffiti-file itselfe and it seems you are right, crap. After all, the effect-file is 18 seconds long. How can I scale the effect on the duration, so it fits in every clip??
    for example: my 18seconds-effect in a new 20 seconds-clip, without leaving my keyframes in the correct time.
    btw, I know, that I can´t squeeze it in 2 seconds, only in equal or longer time clips 😉
    Stefan
  • Peter Mcauley
    June 26, 2008 at 10:09 pm
    You need to use the function in Graffiti titled Keep Keyframe Time to do that. Try saving the effect to the Library Browser and then applying it to a longer clip with this function enabled and then disabled to see how it works.
    Cheers,
    Peter.
  • Stefan Sarkuso
    June 27, 2008 at 6:16 am
    I´ll give it a try when I´m home. Thanks in advance for your fast replys :))
  • Stefan Sarkuso
    June 27, 2008 at 9:43 am
    Hi Peter!
    Thanks a lot – it works! :))
    I still had to find the checkbox, hidden in the window “keyframe palette”, but the search was worth it!!
    I wish you a nice weekend!
    bye 🙂
  • Peter Mcauley
    June 28, 2008 at 2:53 pm
    Glad to hear that worked Stefan.
    Cheers,
    Peter.
