boris fx within edius
Posted by Steve Newbert on March 30, 2010 at 9:43 pmis it possible to save boris fx transitions within edius 5.2?
Boris (9.3) works with the latest edius 5.2 – however, if I try to save an effect, restart the program (edius) then reload the saved preset – all i get is a dissolve. The transition is gone.
thanks
SteveMatt Mullen replied 16 years, 6 months ago 2 Members · 6 Replies -
Matt Mullen
March 31, 2010 at 1:57 pmSteve,
How are you saving the “presets”.
If you work in standalone you can try saving out the Boris FX settings.
So you launch FX standalone or as a plug, when you get the effect you want choose File> save settings as.
Then if you want to use those settings again you can simply open them in another instance of the effect.
Also we got your voicemail. You can always e-mail us direct: support@borisfx.com
Let me know if you need a call.
-Matt
Steve Newbert
March 31, 2010 at 2:33 pmthanks for responding.
I understand that part, but I am trying to streamline and save out multiple fx that I will use repeatedly within edius in the effect window. I want to just drop down individual effects without having to load boris each time and go thru all the different directories, since I’ll probably be using a group of maybe 35 effects all the time. It does work within 1 instance of edius, but once I close the program, and reopen it, I lose the fx. the names are still there, but when applied, they only appear as cuts – with no fx visible.Steve
215-677-9458
cel 215-760-2396Steve Newbert
All Occasion Video Prod.
Phila. Pa.
http://www.aovproductions.com -
Matt Mullen
March 31, 2010 at 2:59 pmAs you’re experiencing I’m not sure this is possible.
I’ll look into this though and let you know.
-Matt
Matt Mullen
March 31, 2010 at 4:43 pmSteve,
I was able to confirm that at this time it is not possible to save host presets in Edius with FX.
Steve Newbert
March 31, 2010 at 5:15 pmHi Matt,
thanks for the quick response and thanks for checking it out.
Do you think this is something that may be added to boris in the future? Are other systems like FCP or Vegas able to do this with borisFX? I’m not familiar with using either of these. Is there a way to suggest this as a ‘fix’ for the next upgrade?Steve
Steve Newbert
Phila. Pa.
Matt Mullen
March 31, 2010 at 6:01 pmIt has been brought up as a “feature request”.
Whether or not it makes it in the next release is uncertain.
