Activity Forums Boris FX Boris FX very basic getting started needed..
  • Boris FX very basic getting started needed..
    Posted by David Hicks on February 9, 2017 at 8:18 pm
    Hi
    I’m a Newbie to CC and to Boris FX. I use Lightworks NLE and have recently purchased Boris FX & Grafitti. Ordinarily, Boris runs under Lightworks natively but only under Win 64-Bit, but a hiccup from LWKS Support before purchase informed me that it ‘would’ run under Win 32-Bit.
    So, I have to run Boris as standalone until I upgrade to 64-Bit. When running natively if you want to add say a transition the host nicely loads the 2 clips i.e. Incoming Video 1 & Outgoing Video 2 into the Boris GUI at launch. Loading them manually correctly in stand-alone mode seems to be illuding me.
    So can anybody point me toward a very basic getting started doc or video tutorial that shows how to load the the clips, I can go from there.
    Many thanks,
    Regards, David
    Peter Mcauley replied 9 years, 6 months ago 2 Members · 1 Reply
  • Peter Mcauley
    February 10, 2017 at 6:22 pm
    Hi David,
    Please contact me offline at (peterm@borisfx.com) and I’ll work with you directly on this.
    Peter.
