Activity › Forums › Media 100 › Boris FX picture motion path – non flicker?
  • Boris FX picture motion path – non flicker?
    Posted by Andrew Mehta on November 26, 2006 at 3:48 pm
    Hi, I imported a jpeg into Boris FX 6.01, animated it the way I wanted, and then came back to Media100.
    When I render it, it flickers.
    In some shots of animated videogame screen shots, the flickering makes it look like certain elements in the picture are flashing.
    I just went into After Effects and did the same, and had no problems. So I’ve achieved the effect I wanted to achieve, it’s not hindering my work.
    But it would be nice to do it in Boris FX and Media100 in future, so I don’t have to leave the programme and go into After Effects.
    My guess is some sort of anti-aliasing is going on, creating problems when things move. Or maybe it’s a lower field / upper field thing. But then it’s a still picture imported, not footage, so I don’t have those options in the media panel.
    Interestingly, if it’s just a still image, non-animated, it doesn’t flicker in the Boris Preview, but does when rendered.
    And FYI both images were scaled up a couple of hundred percent.
    I have Media100 7.5 in OS9,
    G4 Dual 400 Gigabit Ethernet
    Boris FX 6.01
    Kieran Matthew replied 19 years, 10 months ago 2 Members · 1 Reply
  • Kieran Matthew
    November 29, 2006 at 6:43 pm
    Hi Ajmetz,
    The problem is interlace noise as you suspected. It can be solved by engaging the “1:2:1 deflicker” option in the local project settings of the Boris Preferences pane. The picture gets a little softer but you lose the flicker.
    In some cases I find the softening actually improves the feel of the picture.
    Hope that helps
    K
