Activity Forums Boris FX Boris FX in Premiere 6.5
  • Boris FX in Premiere 6.5
    Posted by Mike Robinson on February 9, 2010 at 10:56 pm
    Are premiere 6.5 and Boris FX 8 compatible? Also,it seems that there is compatibility issue with my video card(NVIDIA GeForce 8400 GS).
    The ERROR MESSAGE:
    A component of your system has been detected which is not officially supported by Boris FX for OpenGL accelerator previews. The Boris FX state will default to off, but may be re-enabled from the Preference
    or Preview Menu. This has impact on the quality or performance of an effect’s final render.
    Status:Your system’s video card driver version is not supported by
    Boris FX.
    END MESSAGE
    The startup screen flashes on and then then close FX 8. Does anyone know what is wrong?
    Mike R.
    Jon Kozenko replied 16 years, 6 months ago 2 Members · 1 Reply
  • Jon Kozenko
    February 10, 2010 at 10:52 pm
    FX 8, I believe, should be able to install into and work with Premiere 6.5, but note that FX 8 is the last version that would work with that version of Premiere. As for the error, this shouldn’t prevent the software from launching. Is FX 8 able to launch as a stand-alone program? If it is, shoot me an email at support, as you will likely need a file to dis-engage the OpenGL in FX8, and I cannot give that to you here.
