Activity Forums Boris FX Boris FX fxplug support for Motion 5
  • Boris FX fxplug support for Motion 5
    Posted by Ashton Smith on August 20, 2011 at 5:56 pm
    I haven’t been able to find a single mention, positive or negative, about compatibility of Boris Contiunum with Motion 5 on Boris’s website. Almost as if Boris has no knowledge about Motion 5.
    I know Motion 5 supports fxplug. Several of my previous fxplug plug-ins are present in 5, but the one’s from Boris are not. They are just not listed.
    Currently, my Boris Contiunum Unit appears in FCP 7. I would continue to use them In Motion 4, but they make Motion 4 unusable because of a crash on startup with an error explicitly blaming BorisFX for the crash. Finally, they are not visible in Motion 5 at all.
    Before it starts, I am also aware that FCP X does not support plug-ins. That however shouldn’t stop Motion that does support fxplug.
    Any ideas?
    Mike Menczer replied 15 years ago 3 Members · 5 Replies
  • Ashton Smith
    August 22, 2011 at 2:47 pm
    Well, I answered my own question partially. Motion 5 uses FXplug2 and BCC needs to be updated for that.
    https://www.borisfx.com/aboutboris/boris-fx-apple-final-cut-pro-x.php
    Still haven’t found out why it is crashing my Motion 4 though.
  • Mike Menczer
    August 31, 2011 at 10:53 pm
    I have noticed that my Motion 4 is crashing just after the splash screen.
    The error message says the BorisFX BCC is the culprit.
    I recently updated my iMac (mid2011) to Lion 10.7.1 and I am using the BCC 7.0.4 version.
    All Apple Software Updates have been done, this includes ProApps..
    My Temporary Solution is: To Use Motion 4… Un-install BCC. (obviously, I lose the great functionality of these plug-ins.)
    I then re-install BCC and use in FCP 7.
    Hopefully Boris will come up with a solution, soon.
    I do have Motion 5 installed on my system, but not the other FCP-X or Compressor X.
    BCC shows up in Motion 5 but does not work as per BorisFX press releases. Hopefully soon!
    Although Motion 5 is really slow.
  • Jordan Huett
    September 15, 2011 at 12:07 am
    Ok, so how did you fix this? How do you delete the Boris so that Motion 4 can continue to open up. I prefer Motion 4 than I do Motion 5
  • Mike Menczer
    September 15, 2011 at 4:42 pm
    Jordan,
    I didn’t really fix this situation, I just found a work around.
    I needed to work in Motion 4 and it was crashing on start up. Motion was saying BCC was the problem.
    So in the BCC.dmg (download image) was a BCC un-installer. I ran that program and Motion 4 started working again. But I lose all functionality of BCC, which would be nice to have.
    If I want a BCC filter, I re-install BCC from Same BCC.dmg installer, and I use Final Cut 7, for my effects.
    Not an elegant solution but it works at the moment.
    I have NOT heard back from Boris, Yet. I will probably give them a call instead of just their trouble shooting email path.
    Good Luck, Let me know if you find a solution better than this.
    Mike
    (on iMac 2011, OS-10.7.1 Lion)
  • Mike Menczer
    September 15, 2011 at 6:39 pm
    Jordan,
    I received a response from Boris.
    I hope this helps…..
    Mike
    There is a known issue with the BCC 7 shaders and Motion 4 that is being
    worked on. If you want, you can go to MacHD>Library>Plugins>FxPlug and
    there will be a BCC Shaders Bundle in there that you can remove and the rest
    of the BCC plugins should show up and work in Motion 4 for the time being.
    Thank You
    Jeremy Ellis
    BorisFX Technical Support Team
