Activity Forums Boris FX Boris FX and Liquid 7
  • Boris FX and Liquid 7
    Posted by Simon Allison on April 3, 2006 at 6:30 pm
    Please anbody help
    I have purchased boris fx and instaled
    it works from the desktop but not showing up
    in the effects file in liquid 7 I understand a few people have had
    issues with this.. question anybody any ideas of how to fix it
    is it a Boris issue or a liquid issue ?
    thanks in frustration !!!
    Mark replied 20 years, 5 months ago 2 Members · 5 Replies
  • Mark
    April 4, 2006 at 1:40 am
    Make sure that you install Borisfx after you have installed Liquid.
    Now, in the library within Liquid, it should be under the added clip effects section. Also it should be listed under the added transitions section in the library.
    Regards
    Mark
  • Simon Allison
    April 4, 2006 at 8:42 am
    thanks mark
    have reinstalled liquid again
    then installed FX…. when I load Liquid it reaches
    69% and hangs ..any ideas !?
    simon
  • Mark
    April 4, 2006 at 8:54 am
    Make sure that you leave Liquid alone, even though it is hanging. It is most likely searching for plugs…this can take up to 2 minutes. If that doesn’t work, post in the Avid Liquid forum and we’ll continue there.
    Mark
  • Simon Allison
    April 4, 2006 at 9:57 am
    mark have posted on the avid liquid pro
    forum..left liquid half hr still hanging !!
    simon
  • Mark
    April 4, 2006 at 12:52 pm
    Ok…I meant that you could also post on the Avid Liquid froum here at the COW….
    Regards
    Mark
