Activity › Forums › Boris FX › Boris FX and Final Cut Express
  • Boris FX and Final Cut Express
    Posted by Paolo Tramannoni on October 11, 2009 at 8:54 pm
    I’m interested to the current MUPromo for Boris FX for Final Cut Pro. Since I don’t plan to upgrade from Final Cut Express soon, I wonder if there are ways to use Boris FX and FCE together.
    In case Boris does not work as a plugin, I would be happy enough to use it as a standalone app, to edit clips and then import them into FCE after rendering.
    I read in the forum that someone does this, but I cannot understand at which extent. Boris says you cannot use their product with FCE. I’m mostly interested to the stabilizer, motion blur and light effects. Does someone has a positive experience with them?
    Paolo
    Peter Mcauley replied 16 years, 11 months ago 2 Members · 1 Reply
  • Peter Mcauley
    October 19, 2009 at 3:44 pm
    Hi Paolo,
    You might want to download Boris RED and use that for your effects as RED includes a standalone render function that enables you to render out the effects that you are creating, which you can then import and sequence in FCE.
    You can download the free 2 week trial version of the software here:
    borisfx.com/downloads
    I hope this helps.
    Cheers,
    Peter.
