Activity › Forums › Boris FX › Boris FX 7 and Graffiti Crashes PLEASE HELP
  • Boris FX 7 and Graffiti Crashes PLEASE HELP
    Posted by Brian Gerstenberger on May 24, 2005 at 9:53 pm
    Here’s my problem. When I first put Boris into FCP it worked great. I went and changed some preferences and it worked fine. Then when I went back to change the aspect ratio back to 4:3, both Graffiti and FX would suddenly quit and FCP would go with it. But I could still use the applications so it didn’t bother me all that much. Now, I can’t even open boris without it crashing. Inside FCP HD as soon as I place it on a clip, as a filter, transition, etc it crashes FCP, too. I can’t even use the stand alone keyframer. It crashes as well. I just upgraded to 10.3.7.
    Any help here would be great! Thanks!
    Brian Gerstenberger
    MAC 10.3.7
    Dual 2 GHz G5
    2gb Ram
    Stephen L. noe replied 21 years, 4 months ago 2 Members · 1 Reply
  • Stephen L. noe
    May 25, 2005 at 3:38 am
    have you called boris about it? they’ll likely tell you to delete your boris intialization file. It’s probably corrupt.
