[Boris Flicker Fixer]utilization with Premiere CS5.5
Good morning
Sorry for my English (I use the translator)I ask for help regarding the Boris FX plugins.
I decided to try this plugin in Premiere Pro, with an old film B / N where the flicker is king, and I have noticed that only in the settings Temporal smoth RGB (or YCC), the filter is noted for its effectiveness, however relaxing the definition.As for Frame Analysis mode, returns me an ‘artifact, which present in a frame where else is a fade.
The frame should be black, but here is how it looks. Temporal smoth passing mode is all set with that black frame.
What should I set the Frame Analysis mode or is it better Temporal smoth?
Sincerely thank you
