Activity Forums Apple Final Cut Pro Legacy Boris…. FCP 6 Firewire problems
  • Boris…. FCP 6 Firewire problems
    Posted by Bobby Mikel on September 20, 2007 at 9:03 pm
    I have a Mac Pro with two 2.66 Ghz dual core intel processors and 4 Gb Ram. It has FCP 6.0 installed on it. It used to work fine. Then I installed Boris Red 4.0 and then applied Boris Red 4.1.5 updater to make it support FCP 6.0. After doing this, FCP will no longer recognize the deck (Sony HVR-M25U). The operating system recognizes it, because it shows up under system profiler. I have checked the A/V settings in FCP and it says the deck is missing. Does anyone know what I should do?
    Thanks in advance,
    Bobby
    Bobby Mikel replied 18 years, 12 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    September 21, 2007 at 1:23 am
    Quit FCP, Trash your prefs and try again.
    Jeremy
  • Bobby Mikel
    September 21, 2007 at 12:09 pm
    I already did that. Good idea though. Is there anything else you can think of?
  • Bobby Mikel
    September 21, 2007 at 1:54 pm
    Problem has been resolved. The deck settings were changed to HDV instead of DVCAM. Thanks for the response Jeremy… We have figured it out and all is well.
