Activity Forums Boris FX Boris error message (version mismatch)
  • Boris error message (version mismatch)
    Posted by John Stanowski on February 2, 2010 at 8:22 am
    I’ve started to get an error message when I go to use a Boris Continuum effect in AE. It says:
    “After Effects: effect “effect name here” has version mismatch. Code version is 6.0 and PiPL version is 6.0. (300600).
    Anyone know what this is about?
    Merit Flourish replied 2 years, 9 months ago 3 Members · 2 Replies
  • Jon Kozenko
    February 2, 2010 at 3:56 pm
    That’s an interesting error – I presume that you only have the one version of BCC installed? I would recommend you Uninstall BCC6, and quickly re-launch After Effects to make sure that BCC does not attempt to load – if it does, then you’ll have to remove the plugs manually. Afterwards, re-run the BCC6 installer. Let me know if this helps.
  • John Stanowski
    February 3, 2010 at 5:27 am
    Thanks, I’ll give that a try.
    FYI: this happened right after I installed a trial version of BCC Materials and then shortly after uninstalled it.
    2009 Intel MacPro
    8 cores
    16gig ram
    Snow Leopard (up-to-date)
    Adobe Master Collection CS4
  • Merit Flourish
    December 10, 2023 at 12:02 am
    i updated my graphics driver and my bbc plugins showing version mismatch error in after effects 2018
