Activity Forums Adobe After Effects Boris Conundrum
  • Boris Conundrum
    Posted by Kurt Murphy on October 7, 2005 at 6:33 pm
    I haven’t heard anyone bitching about this, but this problem has really been a pain for me… When I upgraded to OSX, none of my Boris filters were backwards compatible. 90% of my projects use Boris filters of some sort. I now get between 10 and 50 instances where I have to relay the Effects in on older projects… It’s a major pain and I now no longer use Boris Gaussian Blur on any new projects (I use AE’s default), because I don’t know if future versions will give me the same problem.
    Just thought I’d vent….
    thanks,
    kurt murphy
    Kurt Murphy replied 20 years, 10 months ago 2 Members · 2 Replies
  • Darrell
    October 8, 2005 at 2:40 am
    ok, this is what you are supposed to do.
    when you are ready to install the newer version, don’t delete the older plugins, just install the new plugins.
    when you open after effects, you will see the older version first then the newer version.
    hope this helps.
  • Kurt Murphy
    October 10, 2005 at 6:34 pm
    Thanks Darrell, but it didn’t work in this case (I think because they were made for classic)….
    kurt
