Boris Continuum Complete 7 AE DynamiclickManager Error
Posted by Robert Crampton on May 22, 2010 at 11:25 amNot sure if anybody else is getting this error while working with this plugin, it normally occurs around 5-10 minute mark.
C:Program Files(x86)\Common Files\Adobe\CS5\dynamiclickmanager.exe
I’ve researched it and followed the advice here, and no luck.
https://forums.adobe.com/thread/638307?tstart=0
Also the plugin is running slightly sluggish compared with Boris Continuum Complete 6 running on AE CS4.
Luis Cruz replied 16 years, 1 month ago 3 Members · 10 Replies -
Matt Mullen
May 24, 2010 at 2:52 pmare you getting this with a specific filter? what are you doing when you get the error?
Can we get full system specs?
-Matt M.
Robert Crampton
May 24, 2010 at 4:20 pmHello Matt, Pin Art 3D in particular but some of the 2D filters like rain etc still inflict the same old error i.e., DynamiclickManager Error which I’ve posted in the previous post.
I have Window 7 Ultimate
8GB ram with quad core Q9550 (overclocked)
I’ve updated the Visual C++ Library and additional graphics drivers etc. All other plugins work fine in CS5 AE and CS4 AE for example BBC 6 works ok. -
Robert Crampton
May 24, 2010 at 4:55 pmATI radeon 4850 HD 512MB (driver: 10.4 suite at present) also didn’t work with older versions
Robert Crampton
May 24, 2010 at 6:24 pmNo problem. Hope its useful
Crash in progress. Last Logged message was: <4696>
<5> C:Program Files(x86)\Common Files\Adobe\CS5\dynamiclickmanager.exe and
<6088>
<5> C:Program Files(x86)Common FilesAdobeCS5dynamiclickmanager.exe
Matt Mullen
May 24, 2010 at 8:35 pmMy hunch is you are using AE via dynamic link?
If you just bring a clip into AE not via dynamic link do you still get crashes?
-Matt M.
Robert Crampton
May 24, 2010 at 8:59 pmWhat do you mean by bringing in by dynamic link? I haven’t a clue about this facet of AE.
Matt Mullen
May 25, 2010 at 1:41 pmDynamic link is the Adobe feature that allows you to send clips from Premiere Pro to After Effects.
This is what the error is pointing too.
If you are not using this can you clarify what and when the behavior is you are seeing? Can you post screen shots.
Are you getting a crash and then you get the errors when you re-launch.
Luis Cruz
August 11, 2010 at 5:59 pmWas there any solution to this problem? I am getting a lot of DynamicLinks error, and I am not using DynamicLinks!!!
If I use the new Array3D plugin it is a guarantee crash within 5 minutes. I am on nVidia 8800GT running latest developer driver 159.09, but I have also tested with the latest 2 drivers, and the same crashings….
