Activity Forums Adobe After Effects Boris BBC 6
  • Boris BBC 6
    Posted by Marc Müller on April 4, 2009 at 5:04 pm
    Hi out there
    I have downloaded a trial from Boris BBC 6 and the 3D extrude Text is not really 3D . When I rotate the text, it is still a flat 2D panel.What do I handle the wrong way? I am working on CS4 ,MacBook pro.
    Dino Muhic replied 17 years, 4 months ago 2 Members · 1 Reply
  • Dino Muhic
    April 5, 2009 at 2:07 am
    The 3D Effects of BCC have their own transformation options (under TRANSFORMATION). Use these.
    The layer you applied the BCC effect on must not be a 3D layer (turn off the 3D switch if you did turn it on).
    And you have to select “comp camera” in the effect menue to use the AE camera.
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
