Activity › Forums › Boris FX › Boris Avid FX / Continuum will not install
  • Boris Avid FX / Continuum will not install
    Posted by Jon Zanone on May 18, 2010 at 2:21 pm
    Having problems getting Boris Avid FX 5.8 / Continuum to install. Installed Avid 4.0.5 upgrade from 3.0.1. I had Continuum with the old version, but not FX. When I try to install FX, it gets about 90% through the install, then a ‘feature Transfer error’ window pops up:
    Feature: Avid FX for AVX2
    Component: DLL AVX
    File: %ProgramFiles%\
    Error: Access Denied
    I’ve got two AVX folders in the Media Composer folder – could that be the problem?
    Same thing with Contnuum. I’ve uninstalled Continuum, but still no love.
    Thoughts?
    Jon
    Be curious, not judgmental.
    Walt Whitman
    Matt Mullen replied 16 years, 4 months ago 3 Members · 4 Replies
  • Peter Mcauley
    May 18, 2010 at 2:41 pm
    Hi Jon,
    Sounds more like an Avid FX installer issue than anything to do with the Boris products. Please feel free to send a message into our support group (support@borisfx.com) and if one of the technicians can assist you they will certainly do so, however, they may have to bump the issue over to Avid and have one of their techs troubleshoot the installer issue.
    Cheers,
    Peter.
  • Matt Mullen
    May 18, 2010 at 3:09 pm
    Jon,
    This happens because of an incorrect registry entry for the AVX plug-ins folder. Below are the instructions to fix the issue. They are slightly different if you are on a 64 bit OS.
    1.Go to Start: Run.
    2.Type regedit in there.
    3.Browse to HKEY_LOCAL_MACHINE\SOFTWARE\AvidTechnology\AVX
    Plug-ins.
    4.Change the value of AVX2Directory from:
    %ProgramFiles%\Avid\AVX2_Plug-Ins to:
    C:\Program Files\Avid\AVX2_Plug-Ins
    Or on a 64 bit OS
    1.Go to Start: Run.
    3.Browse to HKEY_LOCAL_MACHINE> Software> Wow6432Node>
    Avid Technology>AVX
    C:\Program Files(x86)\Avid\AVX2_Plug-Ins
    Please let me know if this helps.
  • Jon Zanone
    May 18, 2010 at 8:20 pm
    Big thanks to Matthew! The regedit proved to be the ‘key’, pun intended!
    Now, to learn the software!
    Jon
    Walt Whitman
  • Matt Mullen
    May 18, 2010 at 9:06 pm
    Glad to hear it!
    If you have any other questions feel free to post them.
    -Matt M.
