Activity Forums Boris FX Boris + Avid + FC + AE
  • Boris + Avid + FC + AE
    Posted by John Mecklenborg on April 3, 2009 at 6:01 pm
    I’m looking to set up a Mac based edit system in the near future where I am able to use Avid, FC, and AE all on the same system. I would also like to use BCC FX in each of those programs. Would I have to buy a separate plugin set for each program, or is it possible for one set to be used by all three?
    Peter Mcauley replied 17 years, 5 months ago 2 Members · 1 Reply
  • Peter Mcauley
    April 3, 2009 at 7:25 pm
    Hi John,
    The internal architecture for each host is unique; Apple has FxPlug, Avid has AVX, Adobe has AE, Autodesk has Sparks. Because of this each host has uses a separate installer as it installs unique, non-shared sets of code. That being the case, with the set up that you describe you would have to install 3 separate products … BCC AE, BCC AVX, BCC FxPlug. I believe this is true of all 3rd party plug-ins.
    Cheers,
    Peter.
