Activity Forums Boris FX Boris As Filter in FCP
  • Boris As Filter in FCP
    Posted by Jeanne David on April 28, 2005 at 8:47 pm
    We just installed Boris FX 7 to use with FCP HD. Works great with transitions, but I’m having trouble using Boris as a filter. I am picking a video track and applying the Boris filter. From what I have read in the manual, the FX interface is supposed to automatically open, but it doesn’t. The manual also indicates that I can drag other clips into the wells, and then they will be accessible in Boris. I have done that, but when I open Boris there is only one video track with the clip I originally put the Boris filter on. I have also tried having the caps lock key on when I apply the filter as the manual suggests but I still get the same results.
    I must be doing something wrong. Any suggestions?
    Jeanne
    Jeanne David replied 21 years, 5 months ago 2 Members · 2 Replies
  • Scott Fisher
    April 29, 2005 at 2:07 pm
    To get the filter to appear you have to drag it onto your clip. Click the FX7 banner in your viewer windows filter tab. If FX doesn’t open (it can take a while) then click the video tab in your viewer window and FX should launch.
    to access other layers you applied to your wells in FCP, you need to add additional layers. Click on the ‘add 3d plane’ button in your timeline (bottom left button that looks like a diamond). Then you can click the little V2 label on that track and change it to any of thhe layers you put in the wells.
    hope that helps.
  • Jeanne David
    April 29, 2005 at 2:47 pm
    Thanks. That helps. I was skipping a step.
    Jeanne
