Boris AAF transfer FCP>Avid incorrect framerate
Hello all! I’m new at this so here goes…
I’m trialling a version of the Boris AAF transfer plugin & have struck an issue with the frame rate being read incorrectly out the other end of the my AAF export (in Avid)
Basically I want to send my FCP(v7) project to Avid(MCv5.0.3)
FCP settings:
XDCAM EX35mbs – 1920x1080i 50 with Boris AAF export set to match project.Avid settings:
1080i/50 Project – AMA is enabled (not that it matters in this case)The problem is that Avid opens the AAF but thinks my master clips format is 24p? which they are not! In order to open up my sequence it updates to match my project settings (1080i50) because it thinks my AAF sequences master clips are 24p.
When you try a relink on the updated 25fps seq) it fails saying it can’t perform a frame rate conversion..(which makes sense if it were truly 24p material..but its not?)
I’ve double checked my settings in FCP(25fps all the way) & used Media info & even mpeg streamclip to breakdown my source quicktimes which all tell me the same thing..25fps!!
As an extra test, I created a 24p project & imported the AAF which opens as you would expect & even relinks the 24p master clips to 25fps media perfectly without problem.
So things are lost in AAF translation? Has anyone had this problem?
Thanks in advance
FCP v7
Avid MCv5.0.3Mac Pro – 2×3 GHz Quad
OSX 10.6.3
8 GB RAM
Dual partition – Avid/FCP
