Boris 5 won’t render in HD
Posted by Keith Bradley on November 26, 2009 at 4:34 pmHi;
I’m working in Avid 3.0 and have applied the BCC multi stretch transition. It renders fine in SD but when I try the effect in an HD project it renders incomplete. Any ideas?Thanks;
KeithMatt Mullen replied 16 years, 9 months ago 3 Members · 3 Replies -
Boris Yamnitsky
November 27, 2009 at 3:39 pmWhat’s the exact name of the BCC transition? And what “incomplete” exactly means? Off the top of my head I can tell that either the transition settings need adjustment or the system does not finish rendering because of a technical reason. Anyway, more info could help solve the problem.
Boris Yamnitsky
BorisFX -
Keith Bradley
November 27, 2009 at 3:57 pmHi Boris;
Thanks for the reply.
The exact name is BCC Multi Stretch Wipe TR, using the preset ‘blendRays.bcp’.
No keyframes were used, I just dropped it on the time line.
When it renders, the first half of the effect is normal but the 2nd half turns into a motionless circle. I have tried this on 2 different avid systems with the same result: It works fine in SD and craps out in HD. I’m using the latest versions of Avid Media Composer and Boris 5.0.Keith
Matt Mullen
November 30, 2009 at 4:49 pmKeith,
Could you posts screen shots of what you are seeing or send me a bin with an example of this? If I get the bin I can take a look and see if I get this here or if there is a setting that can fix the issue for you.
My e-mail is mattm@borisfx.com
-Matt
