Activity Forums Boris FX Boris 4:3 Library Presets Unchangeable???
  • Boris 4:3 Library Presets Unchangeable???
    Posted by Glass Onion on December 7, 2010 at 3:31 am
    Boris Red 4.3 library is 4:3 and not 16:9. This causes the presets to change the properties of the already established timeline from 4:3 to 16:9 every time a preset is used in a 16:9 project. Is there a workaround for this horror?
    Glass Onion replied 15 years, 9 months ago 2 Members · 2 Replies
  • Peter Mcauley
    December 7, 2010 at 1:54 pm
    Have you tried using using the insert option instead of the overwrite option when adding the preset from the library browser? This function should “insert” or “add” the library composite to the current composite without changing the project settings.
    Hope this helps.
    Peter.
  • Glass Onion
    December 9, 2010 at 10:06 pm
    Thanks that worked well. I really had duh moment.
