Activity › Forums › Apple Final Cut Pro Legacy › Boris 3D tearing
  • Boris 3D tearing
    Posted by Elijah Lynn on February 11, 2009 at 12:12 am
    I am playing around with Boris 3D and I noticed that some of the title is tearing especially the “x”. There is no scaling in the “motion” tab. ProRes codec in NTSC timeline, anamorphic 720×480, upper field first, bottom field first and none exhibit same symptom, video processing>motionf filtering quality=best, render control>always use best quality=checked”.
    Click here for screenshot
    Any ideas?
    Elijah Lynn replied 17 years, 7 months ago 2 Members · 4 Replies
  • David Roth weiss
    February 11, 2009 at 12:36 am
    Hi Elijah,
    What are the codec/compressor settings in the sequence?
    Have you moved the text on the y-axis (up and down in the motion tab? If so, your setting has to be a whole even number.
    Have you tried another font?
    Also, Xs are tough, because they have hard edges that cut across scan lines on a 45-degree angle, which is the worst for stair-stepping. If all else fails, you can try adding a directional blur at 0-degrees and amount 2.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Elijah Lynn
    February 11, 2009 at 1:02 am
    Hey David!
    I am using ProRes, the Y-Axis is 0 and I tried 2 fonts but not much more. It is very odd though. It looks fine in the Boris dialogue box but then when I superimpose it into the timeline it gets larger than it was in the preview window. I suspect there is some sort of scaling going on. I reset the properties for the title too.
    Also, in my screenshot, the “extreme” is the only one I notice jaggies on. The lower “overshoot” does not appear jagged (to my eyes).
    I will try to play with some other fonts and the blur you mentioned.
    Thanks for your feedback
  • David Roth weiss
    February 11, 2009 at 1:13 am
    Overshoot clearly looks excellent and extreme looks like suck — that issue is better known as aliasing. Something isn’t right there, so do try another font.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Elijah Lynn
    February 11, 2009 at 1:25 am
    When I change extreme to the same font as overshoot and the same size the tearing is still there. It appears that the yellow hides it because when it is blue it is visible.
    Here is a screenshot of the preview window and the canvas. Somehow it is scaling it and I have no clue how.
    I have been playing with other fonts too and no matter what it has bad tearing. Very interesting!
