Activity › Forums › Apple Final Cut Pro Legacy › Boris 3D not changing CG
  • Boris 3D not changing CG
    Posted by Leonard Frankford on April 15, 2010 at 9:14 pm
    I recently created a lower-third key in Boris 3D that I wanted to copy and then make slight change to in a new sequence. I double-clicked to launch it into Boris, made the change, hit Apply, and nothing happened. It will not make the change in the sequence. The old CG is still there. Is there something else I have to do to change a CG in the sequence?
    Leonard F.
    Matt Mullen replied 16 years, 5 months ago 3 Members · 6 Replies
  • Don Walker
    April 16, 2010 at 12:35 am
    Did you double click the original, or the copy? A lot of times I think I am modifying one clip and actually be working on another. Could you be doing this?
    Don Walker
    John 3:16
  • Leonard Frankford
    April 16, 2010 at 1:36 pm
    I double-clicked the copy because I didn’t want to change the original in the first timeline. Other CGs I’ve use allow me to copy/change a title. Doesn’t Boris or FCP?
    Leonard F.
  • Don Walker
    April 16, 2010 at 4:03 pm
    I just duplicated your situation on my editor (FCP 7 and SL) and was able to change the copied Boris 3D text just fine. You might want to trash your preferences, re-boot your system and try again.
    Don Walker
    John 3:16
  • Matt Mullen
    April 16, 2010 at 4:44 pm
    Try deleting the preferences for Title 3D. The preference file is
    named “com.borisfx.Title 3D”.
    It is located at: Macintosh HD> Users> > Library> Preference
  • Leonard Frankford
    April 16, 2010 at 6:10 pm
    Success! Thanks.
    Leonard F.
  • Matt Mullen
    April 16, 2010 at 9:06 pm
    Great!
