Activity Forums Apple OS X Booting OSX on USB drive
  • Booting OSX on USB drive
    Posted by Christopher Tay on March 24, 2008 at 2:02 am
    If I clone my boot drive to an external USB drive, will I be able to boot up from the USB drive ?
    Or am I only able to boot from an external firewire drive ?
    -chrispy
    Dustin Lau replied 18 years, 4 months ago 4 Members · 3 Replies
  • Zane Barker
    March 24, 2008 at 3:43 am
    I know you can on a Macbook Air, and you may be able to on an Intel Mac, but don’t quote me on that one.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Eric Hansen
    March 24, 2008 at 7:27 pm
    only Intel-based Apples can be booted from USB. PowerPC-based (G4, G5) can only be booted from firewire. you also have to make sure that you use the correct partition scheme – if you’re using Disk Utility, it will walk you though the options for Intel or PowerPC-based systems.
    i have a MacBook Pro and use Carbon Copy Cloner to keep a clone of my internal drive on an external USB drive. it works great!
    e
    4 G5s, OSx 10.4.11, Final Cut 6.0.2, Kona LH (v5.1)
    Xsan: Xserve 2.0 G5, 3GB RAM, 2 7TB Xserve RAIDs, Sanbox 5200
    Quantum SDLT600A
    decks: Sony HDW-M2000/10 HDCAM, HVR-M10U HDV with HD-Connect, DSR-1500 DVCAM, UVW-1800 BetacamSP
    MacBook Pro: 2.33, 2GB RAM, OSx 10.4.11, Final Cut 6.0.2
    cameras: Panasonic HVX200, Sony FX1 and A1U, Arri S/B 16mm
    skis: Volkl Gotama 183s with 914s and Lange Fluid 120 boots
  • Dustin Lau
    May 28, 2008 at 6:34 pm
    In terms of hard disk cloning utilities, Carbon Copy Cloner, Super Duper and Clonetool Hatchery all get the job done.
    Not a big fan of Time Machine since you can’t boot off it.
