Booting from an Array 0 (Windows XP)
I have a LSI Megaraid 300-8x controller with 7 SATA drives. 6 of the drives are 500GB and the 7th is 1TB. I have 4 RAID 0 arrays of 1TB each, the first three being two each of the 500GB drives and the last being the 1TB drive by itself.
I’m new to this and I could not figure out how to install XP to the array itself. (I had it set up using the BIOS based configuration tool but the XP installer couldn’t find a drive.) So, I grabbed a 40GB IDE drive I had and plugged it in to the MB and used it for the install. The IDE is now C: and the array drives are E: F: G: and H:.
What I want is to now install XP to one of the array drives, make it bootable and then pull the IDE drive altogether. (It’s an older drive and doesn’t perform well at all)
