Activity › Forums › VEGAS Pro › boosting volume
  • boosting volume
    Posted by Doug Ellis on April 18, 2010 at 6:14 am
    I’ve edited together a several of interview clips where one of the interviewees is soft spoken — resulting in low volume in contrast to the others. I set the master volume to 95% when I rendered the initial cut.
    How can I best boost the volume of this one speaker in relationship to the “normal” volume of other speakers?
    David Katauskas replied 16 years, 5 months ago 3 Members · 2 Replies
  • Mike Kujbida
    April 18, 2010 at 1:05 pm
    IMO, that should always stay at 100% as that’s your “reference” setting.
    Apply a Volume Envelope (shortcut key is V) on the timeline and raise the volume for that specific clip.
    You can try bringing his/her clip into Sound Forge (or whatever audio processing tool you have) and raise the overall volume of that speaker.
    I’m sure other folks will offer more suggestions as well.
  • David Katauskas
    April 19, 2010 at 6:10 pm
    You can also try using a compressor. The “Track Compressor” can be used to compress the audio sound to have a more even level and to also make it “sound” louder without it actually increasing the peak level.
