Activity Forums Adobe Premiere Pro Boosting midtones to achieve an infinite white background
  • Boosting midtones to achieve an infinite white background
    Posted by Adam Hannis on August 12, 2016 at 12:04 am
    Hello all,
    I had a lighting issue on set when filming a presenter – I hoped that I would be able to salvage the infinite white background in post.
    I’ve managed to desaturate the background using secondary colour correction on the 3 way corrector menu, but I’m not sure how I can turn the grey of the background into white without affecting the presenter.
    Here is the original:
    And here is what I have managed so far:
    Any advice would me much appreciated.
    P.S. This is my first post on Creative Cow – so apologies if I’ve done made some kind of mistake
    Zoran Bencak replied 9 years, 9 months ago 4 Members · 6 Replies
  • Alan Lloyd
    August 12, 2016 at 4:24 am
    I suspect it can be done with masking and luma keying.
    I won’t say it will be simple. I will say I bet it can be done in Premiere.
  • Tero Ahlfors
    August 12, 2016 at 7:23 am
    This can be done pretty easily in AE. Bring the midtones up with curves, add the extract effect and bring down the white point until you’ve got rid of the background. You’ll probably need to do this separetely for the face (because it’ll blow out with the curve adjustment) and the lower part because the background isn’t evenly lit. Precomp the layers and use that as an alpha matte for the clip.
  • Adam Hannis
    August 25, 2016 at 12:51 am
    Thank you very much!
    From your brief description I managed to get it 99% perfect (apart from a bit of arm hair – barely noticeable)
    Here is the before and after…
  • Adam Hannis
    August 28, 2016 at 4:25 pm
    After completing and exporting the video and watching it full size, the jagged edges do seem more noticeable, along with the little bit of white that keeps moving with his left arm..
    Do you know of any way that I would be able to smoothen this out?
  • Tero Ahlfors
    August 28, 2016 at 4:37 pm
    If you did this in AE then you could use the refine matte effect on the matte layer to clean the edge.
  • Zoran Bencak
    December 5, 2016 at 8:36 pm
    Hello,
    I have very similar situation and I am quite new in AE and PR.. Is it possible to write a little bit more detailed step by step procedure?
    Regars,
    Zoran
