Activity Forums Avid Media Composer Boosting Audio Levels
  • Boosting Audio Levels
    Posted by Jamie Lee on May 6, 2009 at 3:17 pm
    I raised a clip’s audio levels in the Audio Mixer as high as it would let me, but it’s still not quite loud enough. How can I boost the levels even further?
    It’s a simple enough question.. but I can’t seem to figure it out.
    Thanks in advance 🙂
    jamie
    Kenton Vannatten replied 17 years, 4 months ago 3 Members · 2 Replies
  • Jon Zanone
    May 8, 2009 at 1:42 am
    I’d try using the compression effect in the audiosuite tool. Go to tools>audiosuite. When the window opens, you’ll see a pulldown menu – select compression. Click on the square effect icon in the middle of the window, and another window will open. You don’t really need to mess with anything except gain. You can preview and make adjustments from this window.
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Kenton Vannatten
    May 8, 2009 at 4:36 am
    What I usually do is crank it to about 10 in the Mixer, then I’ll use automation gain to boost it a bit more. If that’s still too low, then I’ll double the track and adjust further. If that’s still too low, then I call the audio guy and give him an earful.
    Kenton VanNatten
    Avid Editor (for hire)
