Activity › Forums › Adobe After Effects › Boom Removal issues
  • Boom Removal issues
    Posted by Eli Rezik on December 6, 2013 at 2:02 pm
    Hello people,
    I’m working on a shot where I have to remove a Boompole that’s there almost for the entire shot (as you can see in the file I uploaded)
    https://reels.creativecow.net/film/boompole-shot
    I tried Mocha removal, Wire Removal (BCC and simple) I tried stamping it out and drawing over it… anything I do doesn’t seem good enough
    I got all the takes and unfortunately in all the damn takes the boompole is there so I don’t have even one clean plate to use.
    Any suggestions?
    Eli Rezik replied 12 years, 9 months ago 4 Members · 4 Replies
  • Roland R. kahlenberg
    December 6, 2013 at 5:21 pm
    The camera is pretty much locked off when the boom moves into the shot. My choices in order of preference would be –
    (1) mask off good areas to create a patch and overlay it on boom
    (2) use the clone tool
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • John Cuevas
    December 6, 2013 at 6:36 pm
    (3) scale/re-position past it.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Tero Ahlfors
    December 6, 2013 at 8:31 pm
    The biggest problem is the moving leaves, but you probably could mask out a patch of leaves from the same clip and put that on top of the boom. Remember to feather the mask to get rid of sharp corners.
  • Eli Rezik
    December 6, 2013 at 8:39 pm
    Thanks guys for all the replies,
    So finally I did use the remove tool in Mocha, I got bad results but I use it instead of the original clip
    Then I cut out a patch of leaves and looped it and using the simple tracker I tracked it on top of the original clip
    I blurred the final result a bit and made sure the blur reduces together with the focus pulling.
    the result is okay but it’s not even close to perfect
    So if you got any other suggestions I’d love to hear it
    Thank you
    https://www.youtube.com/elireo
