Activity › Forums › Maxon Cinema 4D › Boole union intersect problem between 2 Capsules
Steve Bentley replied 9 years, 1 month ago 2 Members · 13 Replies
Steve Bentley
August 8, 2017 at 6:05 pmYa mballs can be less than intuitive. You just have to get your inner mercury on.
This should get you part of the way. Ignore the cube aspect of the primitives – I can’t believe that after all these years and all the times you need them there isn’t a single point poly primitive. So I usually just start with cubes or planes and delete points. -
David Yakir
August 8, 2017 at 6:12 pmSteve, thanks a million. I guess I was closer than I thought…really appreciate your help in figuring this out!
