Activity Forums Maxon Cinema 4D Boole Problems
  • Boole Problems
    Posted by David Biederbeck on November 4, 2012 at 5:43 am
    C4D R13, Mac
    I’m working on a project. I’m running into a problem with a boole. It takes away all the geometry before it has completely encapsulated the object. I’ve added geometry but no luck. Any ideas?
    Before animation begins
    After Animation begins
    David Biederbeck replied 13 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    November 4, 2012 at 2:40 pm
    not seeing the problem in your screenshots (too early) but try turning off High Quality in the boole’s settings. If that doesn’t fix it can you post the scene?
  • David Biederbeck
    November 5, 2012 at 4:15 am
    Sorry the screen shots didn’t explain it well!
    Thanks, that did the trick! Best quality is apparently not always best.
