Activity › Forums › Maxon Cinema 4D › Boole on CNC cutting machine
  • Boole on CNC cutting machine
    Posted by Zingaro Felice on March 14, 2012 at 3:17 pm
    Hi there, I need to obtain the clean outline (on vectors) from a shape I designed using a boole. It have a lot of construction lines inside that will make troubles on the CNC machine. Any suggestion?
    Many thanks
    Randy Johnson replied 14 years, 6 months ago 2 Members · 4 Replies
  • Randy Johnson
    March 14, 2012 at 5:32 pm
    Sketch and Toon lets you adjust what lines show and what don’t. The help menu is pretty good for S&T.
    /Randy
  • Zingaro Felice
    March 14, 2012 at 6:13 pm
    thanks Randy! Yes in the meanwhile I just landed there, now I have to understand properly how to get it right 🙂
  • Zingaro Felice
    March 15, 2012 at 3:57 pm
    Mmmhh.. looks like the only one format I can export the vectors is .ai and the client using rhino can’t open it. Tried with other export formats but the construction lines appear again 🙁 I’m stucked
  • Randy Johnson
    March 15, 2012 at 4:48 pm
    I use the rhino IO plug in, its direct line between c4d and rhino.
    https://www.rhino.io/
    rhino does import ai files but not in every way.
    /randy
