Activity Forums Maxon Cinema 4D Boole leaving edges visible
  • Boole leaving edges visible
    Posted by Zach Long on September 26, 2015 at 5:59 pm
    Hi, I have a project set up with one large ‘canvas’ object. Then everything I want booled out is lumped together with a null. The problem is that the edges of one of my cube shapes is showing.
    I’ve tried re-ordering everything in the null group, tried making them all editable as well. I’m guessing theres a way to cut a hole in the cube shape following my ‘wing’ shape, but I can’t figure out how.
    9296_idcardsavedlanyardpic.png.zip
    Thanks for any help
    Brian Jones replied 10 years, 12 months ago 2 Members · 3 Replies
  • Brian Jones
    September 26, 2015 at 8:33 pm
    I’m guessing you want the frame around the head to be cut by the wings. You can put a boole inside a boole so copy the wings (make the depth big enough to cut the box correctly) boole the wings from the box (or boole Union them together if the shapes overlay the right way) and put that boole in your boole group from the card.
  • Zach Long
    September 27, 2015 at 1:59 am
    I just can’t get that to work. It works but it partially exposes the ‘profile pic’ texture no matter how precise I try to be. I may be thinking through it wrong, but I tried for a good couple hours.
    My thought is to do a render without the profile picture and one with, then just mask it out in After Effects. If anyone knows the cause of this exposed edge I’d like to know how to prevent it in the future.
  • Brian Jones
    September 27, 2015 at 4:34 am
    I’d probably have to see the scene file to be able to tell, I’m probably making wrong guesses about your construction.
