Activity › Forums › Maxon Cinema 4D › Boole and complex geometry fail
  • Boole and complex geometry fail
    Posted by Jose Villanueva on June 5, 2019 at 4:20 am
    hi all,
    i got an .stp file from a client that represents a golf ball. it has many polygons due to the dimples. i’m not very well versed in cinema so i’m sure that’s where the majority of my problem is. basically, i have the ball then a cube going left to right to reveal it using a boole. it works for a few frames here and there but the rest of the frames i will see the cube that i’m using to reveal the ball. any help would be awesome and i do appreciate it.
    Jose Villanueva replied 7 years, 3 months ago 2 Members · 2 Replies
  • Brian Jones
    June 5, 2019 at 2:04 pm
    if the .stp is many disconnected polys it might have to be fixed before it will work but try turning off High Quality in the Boole’s settings first
  • Jose Villanueva
    June 5, 2019 at 2:26 pm
    thanks brian,
    unfortunately, i have no further control of the .stp output. i did forget to mention that when clicking off the high quality option, i can see the animation working correctly but the ball itself turns into lines/shading, no material and renders as such. appreciate the help!
