Activity Forums AJA Video Systems Bob Z. or others
  • Bob Z. or others
    Posted by Wayne Orr on March 17, 2006 at 7:44 pm
    Bob, as per your suggestion, I purchased the “Rosetta Stone” from Addenda, and it works perfectly, thank you very much.
    However, I have a new problem. When I try to input the down converted signal from the M10U through the IO, I get a
    garbage signal out. I can connect the tape deck S-video to my stadard def monitor and no problem, but if I hook it up to the IO
    all I get is hash. Same with component. Does this sound familiar?
    No doubt some sort of pilot error, and all suggestions appreciated.
    Wayne
    Bob Zelin replied 20 years, 6 months ago 2 Members · 1 Reply
  • Bob Zelin
    March 17, 2006 at 9:08 pm
    Wayne –
    I answer so many posts, I have no idea of what you are talking about. What is a M10U – it aint’ an AJA converter – is it a VTR ? If you are using FCP, you must go into the Audio/Video Settings/Capture Presets OR the Easy Setups to select the input that you want (for composite, component, SDI, S-Video).
    Give me more info on your system, and I will advise if I can. while you are at it, download the AJA Pro I/O Control panel – this will help you confirm if your I/O is ok, or if it’s just an FCP menu setting.
    bob zelin
