Activity Forums Maxon Cinema 4D Boat Spray
  • Boat Spray
    Posted by Greg Pearson on April 27, 2013 at 4:47 am
    I’m trying to create a bit of sea spray to go with a boat travelling through water. I’ve been looking up tutorials and seeing if they’ll work, and so far haven’t really come close (at least nothing that will take less than 5 minutes to render a frame). Came across something that was looking good, using the PyroCluster Waterfall from the Content Browser – except I’m using R12 and it doesn’t look like the Waterfall was part of this Content Browser. Can anyone suggest how I can get the Waterfall file and see if it works?
    Greg Pearson replied 13 years, 3 months ago 2 Members · 3 Replies
  • Greg Pearson
    April 27, 2013 at 8:33 am
    Actually, I don’t think the Waterfall is part of C4D at all…
    Getting my head around Emitters, but any tips for making the water spray?
  • Jack Cook
    May 1, 2013 at 11:39 am
    Hi Greg,
    I assume you are talking about spray at the bow, flying up as the boat slices through the water. You could try using just a plain particle emitter. I did it this way some years ago. I placed one emitter on either side of the boat, made them a child of the boat so they travel with it. Use a tiny sphere as the particle and you’ll have to emit a lot of them, and play with the settings to get it to look right. I think Pyrocluster would be too slow and clunky to use for this, though I may be wrong (every time I use Pyrocluster I spend too many hours trying to get it right). A regular emitter would render faster, I believe. I’m sure there’s also a Thinking Particles method, but I’m not a TP guru, unfortunately.
    Jack
  • Greg Pearson
    May 2, 2013 at 9:11 am
    Cheers Jack, I’ve been playing with Pyroclusters and seem to be getting close, but I’ll give the simple emitters a try and see how it goes.
    Thanks for the advice
