Activity Forums Apple Final Cut Pro Legacy bmp-sequence in FCP
  • bmp-sequence in FCP
    Posted by Rob Jansen on December 17, 2009 at 6:15 pm
    I need some help with the editing of a 8 mm film. We shot the whole film with 8 mm camera’s and digitalized the footage.
    Now it’s a bmp sequence, but i don’t really now the best way to approach it in Final Cut Pro.
    Someone tolled me you should edit with a converted smaller sized copy and once finished apply your project on the real master footage.
    Does anyone have experience with this?
    Ben Holmes replied 16 years, 9 months ago 2 Members · 1 Reply
  • Ben Holmes
    December 17, 2009 at 7:11 pm
    An image sequence can be turned into a quicktime by opening it in quicktime player (click on ‘open image sequence) – be sure to select the appropriate frame rate.
    Once that is done, you can use Compressor to make this footage the appropriate size (SD or HD etc.) and a proper editing codec – I recommend ProRes for FCP use. This will ensure your footage plays nicely with FCP and fits with any other footage you may use – and easily outputs to DVD, Blu-Ray, tape etc…
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
