Activity Forums Blackmagic Design BMD Up Down Cross Converter problem
  • BMD Up Down Cross Converter problem
    Posted by Zach Legleiter on March 10, 2017 at 5:07 am
    Hey everyone,
    I have a few questions about the BMD UDC converter.
    I have a SD-SDI character generator and I am wanting to up convert the two SDI signals to HD-SDI in 1080i59.94 for use with a BMD ATEM 2 M/E Switcher. I have successfully been able to up convert the Fill signal. But when I try to up convert the Key signal, it is unstable. The video is jumpy, jittery and has a green line at the bottom of the frame.
    I am able to get a good quality SD-SDI key signal out of the character generator (so I am fairly certain the system is working properly, it seems to be an issue with the up conversion. On a side note when I take the SD-SDI and convert it to 720p59.94 the video is rock solid. Again, I need both key and fill signals to be 1080i59.94 for my ATEM.
    Any idea how to remedy this?
    Zach Legleiter replied 9 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
