Activity › Forums › Apple Final Cut Pro › BMD UltraStudio Mini Monitor no output with FCPX
  • BMD UltraStudio Mini Monitor no output with FCPX
    Posted by Chad Smith on August 22, 2016 at 4:40 pm
    Have tried installing various drivers going back to 10.4.1 as mentioned in the BMD forum. However this driver is not doing the trick here nor is the latest build. The UltraStudio Mini Monitor is able to output when using Resolve, PP, AE but not FCPX 10.2.3.
    Does this issue persist with the UltraStudio 4k Extreme?
    Chad Smith replied 10 years ago 4 Members · 9 Replies
  • 9 Replies
  • Francois Jean
    August 22, 2016 at 4:46 pm
    I am using 10.4.3 for my BMD device without any trouble (usual configuration in FCPX ) OSX 10.10.5 , FCPX 10.2.3
    FRANCOIS
  • Chad Smith
    August 22, 2016 at 4:49 pm
    Thanks Francois. What BMD I/O are you running? Do you experience any playback issues like lagging or sticking frames?
  • Francois Jean
    August 22, 2016 at 4:56 pm
    It is an old “Intensity Extreme”, I am mostly using the HDMI output … and everything is great except when Skimming, I use a Matrox MXO2 for SDI output and it is also working fine.
    FRANCOIS
  • Chad Smith
    August 22, 2016 at 5:25 pm
    Are you running those I/O devices over Thunderbolt or USB?
  • Francois Jean
    August 22, 2016 at 5:54 pm
    Thunderbolt , USB device were originally only certified on windows …
    FRANCOIS
  • Kevin Rag
    August 23, 2016 at 1:11 am
    Hi Chad, I had problems too. I rolled back to 10.4.3 and it is working well for me:)
    Am using an Ultrastudio Express, 15″ retina MBP 2.7 GHz Intel core i7 OS 10.11.6
    Kannan Raghavan
    The Big Toad Films Pte. Ltd.
  • Dean Neal
    August 23, 2016 at 1:50 am
    [Francois Jean] “I am using 10.4.3 for my BMD device without any trouble (usual configuration in FCPX ) OSX 10.10.5 , FCPX 10.2.3
    FRANCOIS”
    Me too with my Ultrastudio Express… I use this unit to play content out to Giant Video Screens at major events, using content assembled in FCP X…
    You can imagine how much fun it was to be playing content in front of thousands of people to then see X crash on playback…. or even when you play content through a broadcast monitor to one of your clients…
    Yet again, Blackmagic needs to sharpen up with their product support and bug fixes.
    Dean…
    Dean Neal…
  • Chad Smith
    August 23, 2016 at 3:18 am
    Dean You should really try the AJA t-tap for your live gigs. I find it to work much better than The ultra studio mini in my setup when running FCPX. Back when it did work that is.
    It would be nice to not have to crawl under the desk to plug in the mini every time I want to use Resolve but that does not look like it’s going to happen soon
  • Chad Smith
    September 7, 2016 at 9:14 pm
    Just installed 10.4.1 and still no video output from FCPX.
