Activity Forums Blackmagic Design BMD Ultrastudio 3D or AJA IOXT
  • BMD Ultrastudio 3D or AJA IOXT
    Posted by Alex Grainger on July 2, 2012 at 12:00 pm
    Hi. Has anyone used both the BMD Ultrastudio 3D and the AJA IOXT?
    I intend to use with FCPX as a monitoring device primarily. The biggest sales point of the AJA IOXT is the 2nd thunderbolt port, as I would like to use a non-thunderbolt iMac as a second display via target display mode, but apart from the extra port, are there any major differences in performance or stability?
    Alex Grainger replied 13 years, 11 months ago 3 Members · 4 Replies
  • Martin Smith
    July 4, 2012 at 1:26 am
    Go with AJA. ULtrastudio is BUGGY with Premiere and FCPx even with latest drivers. Depends on your need but you should try before with your workflow. It works like sh$t on mine. Selling mine and looking for something else. And forgot to mention that it is BURNING hot. I could fry eggs with it.
  • Alex Grainger
    July 4, 2012 at 10:07 am
    That’s interesting. I thought my Matrox MXO2 Mini was buggy so I am selling mine to get BMD or AJA! One problem I have is that the playback settings always default back to 29.97 fps every time I load FCPX when I want to use 50i fps. Does this happen with the BMD?
    What are the main bugs you experience?
    I am thinking the AJA is a bit pricey for me so will probably end up with BMD, but would be interested to hear more about specific bugs.
  • Kevin Rag
    September 10, 2012 at 3:18 am
    Hello Alex,
    Which I/O did you finally go with. Am in the same boat trying to decide between IO XT and Ultrastudio 3D. All the extra connection options of the BM might win it for me as the IO XT has only SDI input, no analog or AES/EBU audio inputs.
    Kannan Raghavan
    The Big Toad Films Pte. Ltd.
  • Alex Grainger
    September 10, 2012 at 1:42 pm
    In the end I couldn’t justify the cost of either of those, so I purchase the Intesity Extreme. So far, I have found it to be a very good, stable product. If I ever do 3D work, I would probably use the Ultrastudio 3D.
    I also wanted to have the option of analog inputs as you also said, which the AJA doesn’t have. Also I wanted to use Divinci Resolve, which only works with BMD products.
