Activity › Forums › Creative Community Conversations › BMD Media Express 3 in June
Posted by John Pale on April 22, 2011 at 4:00 pmhttps://www.electronista.com/articles/11/04/22/free.update.brings.prores.3d.4k.support.more/
Noted the souped up new version capture utility for Decklink cards comes out in June (same as FCPX).
Will have XML import support (which hopefully means you can batch capture FCP bins).
Could this mean the rumors were true about FCP X leaving Log and Capture to the card vendors?
Looks like too nice an app (some really great features) for just the few people who use the free utility now……
Jason Jordan replied 14 years, 8 months ago 10 Members · 15 Replies -
David Roth weiss
April 22, 2011 at 4:24 pm[John Pale] “Could this mean the rumors were true about FCP X leaving Log and Capture to the card vendors?”
That’s a possibility that several indicators seem to point at.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Craig Seeman
April 22, 2011 at 4:43 pmIn many respects I think this is a good thing. I hate tying up an NLE with tape capture for hours. I’d like to start on the first tape while capturing the second. I like the Telestream Pipeline concept where you can start editing while the tape is coming in because it’s in an open ended Quicktime wrapper.
With a networked capture computer or maybe taking advantage of Thunderbolt’s bandwidth I can see great potential for ways to capture while continuing to edit.
Now the other feature is going back out to tape when needed. It would be nice not to tie the NLE up for that either but that would require a means to export timeline (XML?) and/or a means to batch capture when needed.
Ingest itself should not tie up an NLE though.
Chris Borjis
April 22, 2011 at 5:37 pmI’ve done a lot of capturing and edit to tape over the years
and it wouldn’t bother me at all….not one bit….if I could capture or output to tape and edit at the same time. -
Eric Jurgenson
April 22, 2011 at 8:36 pmWith a 3rd party export to tape app, you would probably have to export your sequence to a file first – an extra step.
Craig Seeman
April 22, 2011 at 8:49 pm[Eric Jurgenson] “With a 3rd party export to tape app, you would probably have to export your sequence to a file first – an extra step.”
And likely a very fast one. You’re NLE can back to editing instead instead of controlling an HDCAM deck for 90 minutes.
The idea that your NLE should be spending hours controlling tape decks is not very efficient. Certainly in the era where export was slow and network pipes where narrower, it made sense but these days having a separate app on a separate computer is likely much more time and resource efficient. Keep in mind that, over time, the need for tape delivery will be declining.
Chris Kenny
April 22, 2011 at 10:41 pm[Craig Seeman] “Now the other feature is going back out to tape when needed. It would be nice not to tie the NLE up for that either but that would require a means to export timeline (XML?) and/or a means to batch capture when needed.”
I think built-in output is more likely than built-in capturing, because you absolutely need to support video output for monitoring anyway. Allowing monitoring output to be conveniently captured to tape is just a matter of adding some relatively simple deck control.
Plus, built-in output combined with real-time OpenCL-accellerated rendering opens up the possibility for FCP X to offer something like DaVinci Resolve’s PowerMastering, which lets you output to tape in many cases with no rendering step. If output can only be handled externally, then the entire timeline will have to be rendered out to a flattened file first.
But for capturing? Yeah, who cares if that’s built in. Back before most of our work went tapeless, we used to use a third-party app for capturing anyway.
Digital Workflow/Colorist, Nice Dissolve.You should follow me on Twitter here. Or read What is FCP X’s relationship to iMovie? on our blog.
Chris Borjis
April 23, 2011 at 12:20 am[Eric Jurgenson] “With a 3rd party export to tape app, you would probably have to export your sequence to a file first – an extra step.”
For 95% of my projects I have to do that anyways for Blu-Ray/DVD/web versions.
Peter Bosch
April 23, 2011 at 7:31 amIf no capturing is built in, what will the icon with the camera and the arrow on the middle left side mean?
Regards, Peter
Walter Biscardi
April 23, 2011 at 11:57 amAs long as both ingest and output can detect dropped frames, I’m ok with third party apps for this. If the app merely plays through dropped frames, well, that’s gonna burn somebody.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media -
Erik Lindahl
April 23, 2011 at 4:08 pmI don’t see an issue with this at all. Perhaps “log and capture” features will be more stable when tied to a vendor-specific hardware even and MOST people have moved away from tapes for a large portion of the their day-to-day work anyways.
What I do wonder is how Apple has improved the over-all media-management in terms of online / offline workflows, reconnecting, transfering, importing or archiving projects. The current FCP works okey there but it also suffers in quite a few areas.
Some what off-topic but I’d love to see FCPX have proxy- or version support. I’ve found an interesting way of possibly using “auditions” in our current workflow (i.e. you can show the offline-, graded- and posted-clip with-in a few clicks – given that will be PER CLIP which isn’t always what you want).
Erik Lindahl
Freecloud Post Production Services
http://www.freecloud.se
