Activity › Forums › Blackmagic Design › BMD in DV format: Field order complicate & Video quality decrease
  • BMD in DV format: Field order complicate & Video quality decrease
    Posted by Binh Le on November 25, 2005 at 7:47 am
    Hi
    I’m using Decklink SP with Betacam SP – BMD Driver 5.2/XP SP1/PP 1.5.1.
    I have 2 problems:
    – In PP1.5.1 with BMD project, when I reverse video (speed -100%), I have to revert field order of video footage. Video output to Analog OK, but when I export timeline to MPEG II file then at the footage was revert field, the video is not smothing (it’s flicker) but another footage is OK.
    – Video was captured in hard disk (DV or YUV 8bit format), I play it to the analog monitor then it’s darker than source. I view soure and the Video in the same monitor at same time. (I increased gain and gama to maximum in BMD in Control Panel).
    Any one have same problem? Could you show me to fix them.
    Thanks so much.
    Binh Le.
    Binh Le replied 20 years, 10 months ago 2 Members · 2 Replies
  • Wolf
    November 25, 2005 at 8:59 am
    Hi
    when you export a clip: at the Export Movie Settings -> Keyframe and Rendering Options
    click Deinterlace Video Footage.
    I am not sure, but it is worth an attempt.
    For you color problem, i have no idea, perhaps try first 5.2.2
    Greetings
    Claus-Peter
  • Binh Le
    November 26, 2005 at 7:21 am
    ? I have tried 5.2.2 driver but the color problem is the same.
    Same with Margus problem: https://icon.ee/demobars.jpg
    ? The field order for reverse clip is the same but more bug: appear grid green in the Program windows in PP 1.5.1 when I set cusor at clip was reverse but Monitor is OK.
    ? 5.2.2 driver not automatic add Preset Setting in to PP 1.5.1, I have to do manual.
    Thanks for your suggestion
    Binh Le.
