Activity Forums Blackmagic Design BMD Extreme – ppro2 23.98psf SD sequence problem
  • BMD Extreme – ppro2 23.98psf SD sequence problem
    Posted by Bernardo on August 16, 2006 at 8:04 pm
    Hi All.
    I’m working in a 23.98 SD(BMD23.98 preset) sequence, with ppro2 and BMD extreme PCIe.
    When import a DV with 24pa(advanced) everything looks nice.
    But in the same sequence if I import a TGA at 23.98, I get some weird motion.
    Looks like Ppro2 it’s not adding the 2:3 pulldown correctly..
    Even if render my 24pa (advanced puldown that was good before), after the render I get this weird motion artifacts..
    If I play the same TGA sequence in 30p sequence everything looks ok.
    there’s some workaround?
    thanks in advance.
    Bernardo
    Bernardo replied 20 years ago 2 Members · 2 Replies
  • Lance Bachelder
    August 20, 2006 at 6:13 am
    Why are you working 23.98? 24pA is 23.976 – render your targa’s at 23.976 or re-interpret your footage to 23.976.
    Lance Bachelder
    Southern California
    Cow Forum Host- Magic Bullet
  • Bernardo
    August 21, 2006 at 1:44 pm
    Thanks Lance.
    But i’m already doing it …
