Activity › Forums › Apple Final Cut Pro › BMD driver 10.6.5 – still useless
Posted by Bret Williams on May 4, 2016 at 5:19 pmJeremy Garchow replied 10 years, 3 months ago 3 Members · 10 Replies -
Oliver Peters
May 4, 2016 at 9:34 pm10.6.4 on El Cap is running fine for me.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Jeremy Garchow
May 24, 2016 at 1:30 amWow.
I had three crashes today, will now download 10.6.6 immediately!
Thanks for the update.
Bret Williams
May 24, 2016 at 2:13 amWith prior versions I couldn’t go 2 minutes. No joke. I bought an AJA it was so bad. And while the performance of the AJA us similar, the interface was horrible. And it often wouldn’t let go of the app after you quit.
.I see in the BMD notes that it fixes some SDI bug. Out of curiosity how are you monitoring and what are you home up to? I’m using a Flanders LM series via SDI.Good luck!
Jeremy Garchow
May 24, 2016 at 2:19 amSDI out to a patch panel, SDI to a few different monitors and devices.
Bret Williams
May 24, 2016 at 2:13 pmNever mind. F* me. Crashing out to decklink CMIO again. (plugs back in AJA)
