Activity Forums Blackmagic Design BMD Camera Converter Settings
  • BMD Camera Converter Settings
    Posted by Toni Bihler on September 17, 2014 at 10:10 am
    Hi there!
    I checked some other threads but can’t seem to find a straight answer to this question: Is there a way to change the output signal of a BMD Camera Converter from 1080p to 1080i?
    I have a system setup that brings three camera sources and one laptop-source into a BMD Studio Converter and from there into an ATEM 1. Each signal runs through a Camera Converter. All signals are 1080i except for the laptop signal which is 1080p.
    I downloaded the Blackmagic Converter Utility, but that does not give me any options regarding this problem.
    Any hints, ideas etc?
    Any help appreciated! Thanks!
    Toni
    Toni Bihler replied 12 years ago 2 Members · 2 Replies
  • Chad Pearson
    September 17, 2014 at 8:18 pm
    No. The camera converter does not alter the video signal as it passes through in any way. You will need to change the computer’s display settings to output 1080i (try setting the computer to 1920×1080 29hz interlaced)
  • Toni Bihler
    September 18, 2014 at 3:50 am
    Thanks, I appreciate it! I can change the output settings on a Mac Book Pro to make it work (1080i 50Hz actually since I’m in Europe), but a DELL Workstation running Windows 7 gives me some problems. It only lets me set the signal output to 1920×1080 but doesn’t specify if “i” or “p”. I might have to look for a graphic-card driver that lets me do that.
    So thanks again for the quick reply!
    Toni
