Activity Forums Blackmagic Cameras BMCC ProRes Settings
  • BMCC ProRes Settings
    Posted by Asad Javed on September 20, 2015 at 12:46 am
    Hey you guys!
    I got a BMCC and I can see how to change the recording format between ProRes, CinemaDNG and Avid etc. But I can’t seem to figure out how to select what kind of prores to film in (proxy, LT, 422, HQ). The option should appear right there, but it doesn’t.
    How does one do that? Thanks
    Kalleheikki Kannisto replied 10 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Erik Cantu
    September 20, 2015 at 11:25 pm
    The only menu setting to change the recording format on the BMCC is settings/recording/record format and there is cycles through the different formats: RAW, DNxHD and all the ProRes formats.
    What firmware version are you running?
    Erik Cantu
    Video Producer
    RadioU TV & Animal Basement
    14 years experience as a fulltime broadcast shooter, editor & broadcast designer.
  • Asad Javed
    September 21, 2015 at 5:08 am
    Hey Eric
    That’s exactly where I’m looking. I can cycle through “ProRes”, “Raw 2.5k” and “DNxHD”, but there is no choice in what kind of ProRes I’m filming. It just shows “ProRes”. In my recordings it appears that it’s ProRes HQ by the file size, but I need to film in ProRes 422. Should I be able to see all the ProRes options (Proxy, 422LT, 422, HQ)?
    I just updated the firmware yestersay (9/20) so it’s up-to-date. Cant figure out how to check the exact version for you.
    Any ideas how (and if) i can swap between ProRes modes?
  • Deleted User
    September 21, 2015 at 5:39 am
    The most current firmware specifically for the BMCC is version 2.1, available here:
    https://www.blackmagicdesign.com/support/family/professional-cameras
    If you install (or reinstall) v.2.1, are you then able to select multiple ProRes recording modes?
    https://www.peterdv.com
    Blog: https://herefortheweather.wordpress.com
  • Kalleheikki Kannisto
    September 21, 2015 at 6:55 pm
    I updated my BMCC 2.5K firmware recently and do have those options available.
  • Erik Cantu
    September 23, 2015 at 3:16 pm
    I’m sorry, but it only sounds like the firmware running on the camera is wrong and the most current version of the blackmagic camera utility needs to be installed on your computer, rebooted and then update the camera via USB connected between them.
    Erik Cantu
    Video Producer
  • Asad Javed
    September 23, 2015 at 3:33 pm
    Thanks you guys! It was the firmware. I’m pretty new to Blackmagic, and I figured their utility would keep the camera up to date, but turns out you just have to download the update manually each time. 2.1 is definitely letting me do all that I was missing
    September 24, 2015 at 10:06 am
    I’m very glad you asked, for I didn’t realize this was added in the firmware update. I was happy enough to get audio level monitoring! Many other great improvements in the update: these extended ProRes options and the ability to format SSDs in-camera among them.
