Activity Forums Blackmagic Cameras BMCC FILE Size Limitations
  • BMCC FILE Size Limitations
    Posted by Richard Martz on January 22, 2014 at 9:30 pm
    I wanted to pose a question and open a discussion. I am a fairly new owner of a BMCC and I’m learning a lot about the camera. One thing I found interesting this week involved the maximum file length that I’m getting on the BMCC. I found myself recording some lengthy interviews and I was wondering if I should be “double punching” the record button periodically as you would with a DSLR when recording a lengthy event. That practice has been my “work around” for the limited file length present in most DSLR systems.
    I knew the BMCC file had no “practical limitations” but was wondering if there were FINITE limitations. And it turns out that there ARE definite file size limitations. And yes…I know you are always limited by the size of your SSD.
    So when I returned to the studio I quickly constructed a test to see how long I could record without the BMCC creating a new file. I also wanted to know if those file length limitations were different for different frame rates. Here is what I have determined so far:
    1920 x 1080 / 29.97 will record for 128 minutes before creating a gapless new file. 230,169 Frames
    1920 x 1080 / 23.976 will record for 160 minutes before creating a gapless new file. 230,169 Frames
    These are the only frame rates I’m working with. I’m curious if anyone else has bothered with this and what this largely useless information means to anyone.
    Sincerely,
    Richard Martz
    MagicMartz Media
    Atlanta, GA
    FCP 7
    FCP X
    Blackmagic Cinema Camera
    ADOBE CREATIVE SUITE CC
    Premiere Pro
    DaVinci Resolve 9.0
    MAC 8 core
    After Effects
    PhotoShop
    Illustrator
    Sony HD Cameras
    24′ Camera Crane with Motorhead
    8′ jib arm
    20K watts of lighting
    Multitrack audio
    Teleprompters
    Grip Truck/trailer
    Location video monitoring
    Door and hood mounts
    Lots of other Fun Stuff!
    Richard Martz replied 12 years, 7 months ago 2 Members · 2 Replies
  • Michael Phillips
    February 1, 2014 at 8:27 pm
    Seeing as the total number of frames is the same, I suspect the file size itself is also the same. Duration is based on total number of frames divided by frame rate, so a slower rate will have longer times.
    Michael
  • Richard Martz
    February 1, 2014 at 8:32 pm
    I suppose so. But I admit that I didn’t actually count each frame. 🙂
    Sincerely,
    Richard Martz
    MagicMartz Media
    Atlanta, GA
    FCP 7
    FCP X
    Premiere Pro
    DaVinci Resolve 9.0
    MAC 8 core
    After Effects
    PhotoShop
    Illustrator
    Sony HD Cameras
    8′ jib arm
    Multitrack audio
    Teleprompters
    Grip Truck/trailer
