Activity › Forums › Blackmagic Cameras › BMCC 2.5k ef Metabones
  • BMCC 2.5k ef Metabones
    Posted by Ali Quintana on November 22, 2015 at 2:41 am
    I wanted to know if I can change the 2k BMCC in to a full frame view with a speedbooster.
    So that I can basically use EF full frame lenses on the 2.5 k camera and for instance get 24mm view with a 24 mm lens.
    Peter Timberlake replied 8 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Erik Cantu
    November 22, 2015 at 3:27 pm
    No.
    Erik Cantu
    Video Producer
    RadioU TV & Animal Basement
    14 years experience as a fulltime broadcast shooter, editor & broadcast designer.
  • Ali Quintana
    November 25, 2015 at 7:26 pm
    Thats very Clear…..
    OK, now I have a great full frame EF lens, the Canon 24-70mm 2.8.
    Can I still use it on the 2.5K BMCC? It seems to work great!
  • Erik Cantu
    November 28, 2015 at 5:56 pm
    Why don’t you mention which lens mount your BMCC has.
    Erik Cantu
    Video Producer
  • Ali Quintana
    December 2, 2015 at 1:52 am
    EF mount. Sorry, how could I forget to mention that.
  • Erik Cantu
    December 3, 2015 at 3:30 pm
    Then of course the 24-70mm EF lens can be mounted to the EF mount of the BMCC.
    I shoot most often with a Canon 17-55mm EF lens.
    Erik Cantu
    Video Producer
  • Ali Quintana
    December 5, 2015 at 1:09 am
    Yes, but I would be shooting with a full frame lens (24-70mm 2.8) on a cropped frame camera (BMCC).
    I was hoping for some kind of adapter that can change the view to full frame. So I can see full frame through the lens. But you already answered that, thanks.
    Now is there any big disadvantage in image quality while shooting with a full frame lens (24-70mm 2.8) on a cropped frame camera (BMCC)???
  • Erik Cantu
    December 6, 2015 at 2:01 am
    Focal length of focal length regardless of the sensor size. A 24-70mm Full frame sized lens when mounted on a smaller sensor camera (like for example a mirco four thirds sensor) will create the same composed image and quality as 24-70mm lens formatted for the smaller sensor size (like the m4/3 example).
    Smaller format lenses can’t be mounted to larger sensor camera as the image they project to the sensor is smaller, designer for their camera format’s smaller sensor.
    Any loss in quality, wouldn’t be due the the lens, but physical limitations of technology on the smaller sensor.
    As a video professional, consider reading up on lens optics.
    Erik Cantu
    Video Producer
  • Peter Timberlake
    March 27, 2018 at 12:10 am
    don’t be a dick bro
