Activity › Forums › Blackmagic Cameras › BM URSA Mini Pro 4.6k settings backup
  • BM URSA Mini Pro 4.6k settings backup
    Posted by Dan Anon on September 3, 2024 at 5:23 pm
    I have an issue with one of three of the above cameras, and I think the only way to alleviate it (and other mysterious things) is to factory reset the camera. The manual tells me to backup saved LUTS and settings but it doesn’t tell *how* to back it up.
    Please, someone tell me how to “backup the camera settings”.
    With thanks,
    Dan
    Brie Clayton replied 2 years ago 3 Members · 3 Replies
  • Gary Adams
    September 4, 2024 at 12:07 am
    Hello Dan. Please check the section in the manual under saving and loading presets. Set up the camera as you would like then export the settings to one of the drives. Reset the camera then import those presets. That is the general process. I hope this helps.
    Gary
  • Dan Anon
    September 4, 2024 at 12:27 am
    Thanks, Gary. As a geek, when I saw the word “backup” in the manual I assumed that the camera had a menu option somewhere named backup. I was wrong.
    You were correct. Build profile, save profile, export profile. In that order. The manual didn’t make it as clear as it actually is.
    Regards,
    Dan
  • Brie Clayton
    September 4, 2024 at 1:29 pm
    Thank you for solving this, Gary!
